water pump HELP!
Old 09-09-05, 09:21 PM
dean s
dean s's Avatar
Default water pump HELP!
my water pump gave up on me today ,$260 tow bill home and then parts!! well I want to do the work myself but I have no manual and after today it'll be awhile before I can afford a set! if anyone could help me with a scan of thier mannual or give me the play by play on how to do this and the timing belt I'll forever be in your dept!
DEAN
Old 09-10-05, 01:00 PM
damon
damon's Avatar
Think you have an SC400.
Great link to help you out.
http://www.lexls.com/tutorials/engine/timingbelt.html
good luck.
Old 09-10-05, 09:34 PM
koolaidman
koolaidman's Avatar
good luck.
pretty good
but u can skip step 9
u dont need a puller its not a domestic they are not pressed it. just need 2 pry bars
in step 42 he used too much fpig a very thin coat is all u need
it doesnt take lexus mechanics 10-15 hours ive done it in 5
step 2 should be put the engine on tpc for piston number 1
if u get a lexus timing belt there are painted marks on the belt its self that should algined with the marks on the cam gears and the crank sprocket
Old 09-11-05, 11:41 AM
dean s
dean s's Avatar
Default Thanxs
Hey thanks guys! can you tell me if the pully "crankshaft" is right or left hand thread? tried breakerbar and starter trick to no avail, it won't break free!!!!
Old 09-11-05, 06:56 PM
koolaidman
koolaidman's Avatar
turn to left if u dont have an impact ur going to need to put the belt back on and stick a screw driver in 1 of the pullies or harmonic balancer
pNOYriyal
Performance & Maintenance
04-09-17 11:25 PM
gostsc
08-10-09 09:48 AM
Neucorp
SC- 1st Gen (1992-2000)
12-31-07 09:37 AM
dave95sc
10-11-04 05:30 AM
Quick Reply: water pump HELP!
