Spark Plugs - Should I stay or should I go?
I have a 97 LS and have been running Bosch +4's in it for over 4 years and haven't had a problem. I think it's about time for a plug change and was wondering what the consensus might be whether I should stay with the +4's or go with maybe Denso Platnium 2's or Denso Iridium?
Any comments that would help in my decision are appreciated.
Thanks,
Wes
Thanks,
Wes
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Thanks,
Wes
Thanks,
Wes
Your LS came stock with NGK laser platinums, NGK # BKR6EP-11 (NGK stock # 2978). Gap is .044. The correct Denso iridium part number would be PK20R-11. I would personally change to one of them & get away from Bosch as overall, they are much better choices over the +4's for your LS 400.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
The Denso site says I should use IK20.
http://www.densoiridium.com/find_par...&action=Search
Is there a difference?
Wes
Wes
The Denso site says I need IK20's for my 01 ES too, but the correct OE Denso is SK20R11.
Denso Iridium is IK20; and the Denso Double Platinum is PK20R11
Iridium cost is $11.99
Double Platinum cost is $6.82
Are you sure you have your numbers right?
Wes
Wes
Wes
Wes
And sorry my mistake, the PK's I mentioned in my previous post are platinums not OE iridiums. My bad. But yes the numbers are correct.
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Originally Posted by sha4000
i just took my original plugs out at 120k and the # is sk20r11 and they were still good i just changed them b/c it was recommended maintenance
Just wondering how much did the plugs cost you for replacement?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
yeah, you should try the Denso Iridium's. I have mine in my es for over 60k miles now, and their still in good condition.
A little expensive, but definitely worth it, considering you don't have to replace them until in at least 90,000 miles (the es is a little hard).
A little expensive, but definitely worth it, considering you have to replace them until in at least 90,000 miles (the es is a little hard).
i didnt get the iridium plugs manly b/c i just wanted to take the old ones out to see what kind of condition they were in which would also tell me how my engine is running. i dont really know anything about iridium vs. platinum. so i went to autozone and got some ngk v-power plugs thats also recomm. for my car to see what the difference would be in acceleration and starting. im not too concerned about changing plugs every 60k or 120k b/c i do all my own maintenance or whatever else needs to be done short of dropping the engine or tranny b/c you really need a lift for some things. anyway i changed the plugs like 2 days ago and it seems like the new plugs give better accel.(of course) and starting. but im going to run them about a month and if i dont like the fuel economy ill def. chnge them back out for the OE iridiums which cost 4x more. i personally need info to justify that much money for a plug. the iridiums are $9 on that denso site but most other places they are $13
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
Originally Posted by Lexusfreak
I would have at least put NGK laser platinums in instead of the NGK V-power personally. But that's just me.
i hear you but that was the only other plug that they offered for my car esides the bosch and i wasnt going to get those. i dont really know much about spark plugs so i got the v-power. i probably wont keep them in there though.
I'd be courious as to the price between the long life Denso's vs. the NGK iridiums......that's comparing apples to apples. ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
