If the problem isn't the flashing unit?
Old 10-01-05, 03:20 PM
LarryParker
LarryParker's Avatar
Default If the problem isn't the flashing unit?
My right turn signal started flashing at double the normal speed on my 2000 ES300. I ordered received, and installed, a new flashing unit, but the right turn signal still flashes too fast. My turn signal bulbs are not burned out. Does anybody have a thought on what the problem might be?
Old 10-01-05, 08:20 PM
mtsao
mtsao's Avatar
May sound strange, but try changing the matching left bulb. They're usually on the same circuit and if one bulb is beginning to fail, it can cause erratic blinking on the other side.
Mike
Try this file:
File Type: pdf
Old 10-01-05, 09:03 PM
CUMan
CUMan's Avatar
This is a very common problem on the ES models, and it has been discussed numerous times.
Do a search by entering "Fast blinking turn signals" in the search box.
nrusso3487
07-31-18 10:48 PM
ahabion
15
07-26-12 01:46 PM
qhs002
02-24-10 11:05 PM
lasracin
SC- 1st Gen (1992-2000)
09-14-05 06:29 AM
snboarder8
05-16-03 03:14 PM
Quick Reply: If the problem isn't the flashing unit?
