where is my engine oil ?????
I have a 95 GS300 with 118K miles. I bought the car at 110K and switch to mobil 1 synthetic at 114K and I have added almost 2 qts of oil and I have no clue where did it go
car don't have any blue smoke (or smoking at all) so I assumed it did not burned oil. It does have some minor oil leak but not a single drop on the ground when park over night. where else can the oil go??? I plan to switch back to dino oil soon and see how it goes.
I had this problem when I was using Mobil 1 5W-30 for a bit of time, even a gas analysis (like emissions) showed it was not burning oil but it was definitely dropping. I switched to a 0W-40/5W-50 blend of Mobil 1 and no problems since. I have 96K on my RX. I also checked for leaks both at home and at the office, but nothing underneath, no matter if hot or cold and I checked several seals.
You can't win in some places.
Some of my racer friends use Liqui-Moly 10W-60 given issues with 10W-30, especially my friend with an RX-7. Not that I would use Liqui-Moly for my oil, but going to the higher weight helped.
sktn77a
RX - 1st Gen (1999-2003)
08-19-05 10:23 AM
