Quick A/C Question
The reason I am unsure is b/c I have a recharge kit for my Mustang and I attempted to use it on my SC and the line didn't seem to want to attach to the fitting. I guess I am glad I couldn't get it to work after reading some prior post where to DIY kits are frowned upon.
Thanks, I just don't understand why the hose won't clamp onto the fitting and I don't want to keep releasing more freon. Any suggestions?
I am using the fitting, which I believe is the low side, that is close the the passenger side firewall near the manifold. Is this correct?
Safety first, Make sure you have the low side.. If in doubt, take to an A/C shop. In any case, ever wonder why they use gauges? You can overfill the system and blow the compressor seal. Just a thought.
