LS400, 1996 - fan clutch R&R?
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Does anyone have an exploded diagram or a walk through on how to remove and reinstall a new clutch? Mine is dead with a capital D.
Thanks
Thanks
The fan blade has four bolts, easy to remove, 1st get the fan shroud removed and out of the way. Next remove the fan blade. The four bolts left to remove are last to be removed. WD40 those bolts, use 12mm wrench and a hammer (yes hammer) to hit your wrench counterclockwise...a few hits after the wd40 soaks in will loosen the bolts and voila!!
