GS300 30k service!
Re: I did my services at Longo earler this year
Originally posted by Prost
The 30K service is about $200. I paid something like $220 because I had Mobil 1
Guest
Posts: n/a
A lot more
I was told the GS 30K mile service was something like $500 :eek:
Most of this work is labor to change fluids. If you want to do this yourself and save a LOT of money, you can probably buy all the parts and fluids for less than $50. The only unknown is the A/C filter - not sure how or where to buy that part (except from Lexus).
For example, Lexus charges something like $75 for a new air filter. That's friggin robbery. Purolator filters can be had at a local parts store for less than $20.
Thx...Doug
Thx...Doug
Hey Globe,
Just had my 30M service at Glendale. They did a nice job Total cost including tax was $253. This was after the discount for my own mobil 1 oil and filter as well as a 10% discount coupon they mailed to me a while back.
I'm sure some can find it cheaper - especially with non lex service, but this worked out ok for me. BTW, i had everything done. One service advisor told me they did NOT change the tranny fliud at 30K. Make sure you know what they are going to do.
thanks duster.
I'm pretty sure I'm gonna go to Longo for the 30k. They've been great and is alot closer to me than Glendale
253 including tax sounds very good. How come I never get coupons in the mail?!?
Also I remember there was this place online where I can get a list of what they're doing for each service. I think it was Lexus.com but I can't find it. Where can I find something like that?
30K Service...
Up here in Northern California, this is what Lexus of Sacramento will do for 30K Maintenance...
Engine
Engine oil & filter - change
Air filter - replace
Engine operation - check with scope
Cooling system - inspect & replace engine coolant
V-belts - adjust
Service fuel injection system - check
Exhaust system - inspect components and check emissions
Inspect belts/hoses
Chasis
Tires - rotate & set tire pressure
Undercarriage - check for damage and condition of rubber boots
Power steering system - check & add fluid
Transmission
Automatic - replace fluid
Manual - replace fluid
Differential - replace fluid
Brake System
Components (pads, lines, hoses & calipers) - check condition
Brake fluid - replace
Hand brake - check & adjust
Mics
Lubricate chassis, hinges & trunk
Wiper blades - inspect & clean
Test drive car
Wash & vacuum
Electrical
Battery - check
Electrical equipment & lights - check operation
Diagnostic system - check operation
That's what they listed.
http://www.lexusofsacramento.com/f_i...r-maint-1.html
Fusion400
***Hope this help***
Engine
V-belts - adjust
Inspect belts/hoses
Chasis
Transmission
Brake System
Mics
Test drive car
Wash & vacuum
Electrical
Battery - check
Fusion400
