Which tranny fluid should I get
I have a GS4 I want to do the tranny fluid change myself. by draining 2 quarts at a time. I dont know which tranny fluid to get. What about amsoil. were would i get it and wich do I get. thanks
Is there any other fluid you recomend
There is nothing wrong with AMSOIL. I have used it in my vehicle for over a year with NO ill-effects. I also added a transmission cooler, and the combination is awesome. After all this time, the fluid is still as clean and red as it was when I put it in.
The TOYOTA TYPE T-IV will not fare as well. It WILL be dark after 15,000 to 20,000 miles of spirited driving.
GOOD LUCK!
GOOD LUCK!
GOOD LUCK!
GOOD LUCK!
DaveGS4 is the Amsoil guru - search his posts on Amsoil.
You can order it online or try and find someone in your area that sells it.
Jonny
gsrthomas
RX - 1st Gen (1999-2003)
12-31-08 07:41 AM
