IAT within MAF on '96 LS400?
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Pulled the codes on the LS today and was coming up with about 6 different ones, know where the others are but I received one for the MAF and for the IAT.
Did a quick look at the intake tubing and didn't see a seperate IAT soooo I assume it's within the MAF, is this correct?
If this is correct, should I attempt to clean my MAF or just scout out for a used one?
Thanks!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Thanks!
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I can't speak for that sensor in particular, but generally they are nothing more than a 10 cent thermistor on the MAF body.
Troubleshoot all the codes together logically. I highly doubt your IAT sensor is actually bad. If it shows any resistance - the ECU will be happy with it. It doens't make more than a bearly noticeable change in the fuel & ignition tables.
That's the only code now, I had a few random misfire ones due to bad plugs/wires and an O2 sensor one that I have been rid of for a while.
What's the best was to take apart the MAF? From what it looked, it's a single piece.
Soldering to repair doesn't bother me at all if I can get away with that...
Allaretake
Performance & Maintenance
06-03-10 02:36 PM
