did i mess this up?
did i mess this up?
after bleeding the brakes on my sc300, the pedal goes almost to the floor before any real braking force happens. however im still able to get some abs action when i slam the brakes on dry pavement. i can still stop but i just have to step the pedal almost to the floor to do so. its rather scary because it feels like there's no fluid and i wont be able to stop. any thoughts on what is causing this?
the e-brake light on my dash stays lit when the e-brake is off too
possible culprit?: i bled the driver side front caliper by loosening the banjo bolt on the brake line because the top half of the bleeder screw snapped off
If your lucky, "easy out" the bleeder nipple broken in the caliper. Use a good penetrating oil. If your not lucky, replace the caliper. Loosing the hose only adds air to the system.
You might be in the situation where Lexus or Toyota may have to bleed the antilock brakes. To my knowledge, you need their service computer to run and activate the solenoids in the ABS pump.
This way you bleed the entire system. Good luck.
i didnt use a one-man bleeder, i had a friend help me. im pretty sure there is no air in the lines, except mabye in that front drivers side since i didnt use the bleeder screw. i think im just gonna replace the caliper and re-bleed all 4.
start with RR
then LR
then FR
then FL
Always bleed the brakes the furthest from the master cylinder first, then next closest, etc..
If you used the banjo bolt, then the caliper itself has air in it. Fix that, then rebleed in the correct order and you'll be in great shape.
LS400BOY
60
10-05-12 04:36 PM
DamonBoost
SC- 1st Gen (1992-2000)
03-11-03 10:44 AM
