Help... SC's acting up
Hey guys, last nite my car started to act up and few things stopped working all of a sudden. No dome lights, no door lights, no power door locks, and clock keeps reseting. That's all I've found that doesn't work. Before I start tearing things apart to try and find the problem, I wanted to get some feedback and suggestions to what the problem might be. I'm thinking at this point I got a blown fuse, but I've read a couple of posts mentioning dash failures. Any suggestions on where to look for the problem would really help me out.
NY's right. Start with the simplest things first. I had something fairly similar and it ended up being that the negative battery connection was not good enough. A new connector and we were good to go!!
THANKS NY AND KORSU, I'll check all the fuses when I get home from work and I'll keep you guys posted on whether that was the issue. I'm thinking the same thing as ny though.. it seems like it would be the fuse, but considering this is the first lexus I've owned, just wanted to make sure. Thanks a lot for the quick response guys.
Originally Posted by SinisterSC
Hmm, clock keeps resetting..... Is you're battery light comin on?
