check engine light
Old 01-10-06, 07:50 AM
sexilexi
sexilexi's Avatar
Default check engine light
My 99 ES 300 is giving a code of PO446. What should I do?
Old 01-10-06, 08:03 AM
np20412
np20412's Avatar
I don't know if the CEL codes are the same between between the 1999 3.0L Camry and the 1999 ES, I would assume they are though since the engines themselves are both 1MZ-FE. Anyway, the code on the Camry indicates that the Gas filler cap no longer holds a good seal. This seems to be pretty common with the 99 Camry's. People who have replaced the gas cap have seen the CEL go away altogether, while for others the light goes away for a bit and then spits out more codes telling them to replace the Charcoal Canister.
I would replace the gas cap and take it from there, good luck!
Old 01-10-06, 08:43 AM
sexilexi
sexilexi's Avatar
I've tried a new gas cap. Also, the trac off light is on. The CEL/TRAC off light came on for the first time when it was low on fuel, if that helps. I've had it cleared and it comes back after a few days.
Thanks in advance.
Old 01-10-06, 09:00 AM
np20412
np20412's Avatar
I'd be willing to bet then that it is your charcoal canister. This does happen with lots of Camry LE owners as I have read. I also read that after replacing the charcoal canister if your CEL/Trac OFF light remains on, then it is probably due to the VSV (Vacuum Switching Valve) remaining open due to something (most likely a piece of charcoal resulting from the failed charcoal canister) being sucked up into it.
Hope this helps!
Old 01-10-06, 09:39 AM
sexilexi
sexilexi's Avatar
thanks. Is there any way to test it to make sure that's what it is before replacing it completely? What exactly fails on them?
Old 01-10-06, 10:47 AM
lexusk8
lexusk8's Avatar
sexilexi, here are a couple links to help you out with the error code:
http://www.troublecodes.net/Lexus/
https://www.clublexus.com/forums/sho...&highlight=cel
Please consider using the search engine here next time if you have questions; it's a powerful tool everyone should use
Old 01-12-06, 11:24 PM
koolaidman
koolaidman's Avatar
replace the canister
i forget what year but arround that time they started using charcoal canisters. and they werent made very well
Old 01-13-06, 08:43 AM
sexilexi
sexilexi's Avatar
I located it behind the gas tank and inspected all hoses and container for cracks etc. Couldn't see anything visibly wrong with anything. I do occasionally smell gas vapors. It's in there good; how do I get to it to replace it?
Old 01-13-06, 12:24 PM
koolaidman
koolaidman's Avatar
well then u found the problem and good luck getting it out cuz its a pain in the but
RamizBro
ES - 6th Gen (2013-2018)
04-03-17 07:02 PM
joebor1776
06-22-16 09:34 AM
ChanceM40
RX - 1st Gen (1999-2003)
11-23-14 06:36 AM
MikeGoshay
09-24-11 07:10 AM
ed0250
07-24-07 09:42 PM
Quick Reply: check engine light
