Cleaning Fouled Plugs
Old 01-13-06, 04:46 PM
Dx3
Dx3's Avatar
Default Cleaning Fouled Plugs
Guys,
I got some brand new NGK 1 step colder plugs to run with the supercharger. Fuel problems were making the car run very rich which has fouled the plugs. They are pretty expensive and have less than 50 miles on them. Can I clean them up or are they toast??
If I can fix them, what is the best way to go about cleaning them up??
I really don't want to drop another $200 on plugs that are <50 miles old
Thanks,
Jonny
Old 01-13-06, 05:14 PM
VVT-i
VVT-i's Avatar
You can use the carbulator cleaner to clean the plugs and let it dry for about 10 minutes. I did this trick from time to time and its help save customer some money too. But when you get you the car running make sure you keep the idle up so the heat from the combustion chamber will burn all of the fuel deposit on the spark plugs away. Good luck..
Old 01-13-06, 09:21 PM
Dx3
Dx3's Avatar
Hey man,
Thank you for the advice. When you say let it dry for 10 minutes - 10 minutes before what??
Let me know man and thank you again,
Jonny
Old 01-14-06, 12:57 AM
mikeyboy
mikeyboy's Avatar
i think sandblasting works too
Old 01-14-06, 01:20 PM
VVT-i
VVT-i's Avatar
Originally Posted by Dx3
Hey man,
Jonny
I mean 10 minutes before you install them back.
YODAONE
40
03-24-21 05:27 AM
AnthonyMtz
RX - 1st Gen (1999-2003)
15
02-07-15 04:16 PM
BEARCATJER
RX - 3rd Gen (2010-2015)
02-04-13 12:33 PM
djl
Performance & Maintenance
10-08-09 06:49 PM
Vortes
07-20-08 09:33 PM
Quick Reply: Cleaning Fouled Plugs
