Service light
I don't like to take in my car for service due to charges when i can replace everything myself (quoted 700$ for the 30k service)
So, my service light came on for the 30k and i was wondering does it manually turn off after a certain amount of miles or what?
Lexus Connoisseur
From your profile you got a 1997 SC300 and you don't have the maint light back then. I beleive you mean the CEL ( Check Engine Light). If this is the case you will need to get your car check for trouble code.
Service Reminider Light reset procedure. (NOT for turning off the Check Engine Light).
1. With your car OFF, place your key in the ignition and turn to "On". Do not start the car.
2. Find the odometer button and press until it reads the total odometer setting,
(not the Trip A or Trip B setting).
3. Turn the key to OFF.
4. Place your finger back on the odometer button, press and hold. At the same time,
turn the key back to "On".
5. Hold the odometer button in until the MAINT REQD light goes out...should take
about 8-10 seconds.
Good Luck
steviej
about 8-10 seconds.
Good Luck
steviej
about 8-10 seconds.
Good Luck
steviej
about 8-10 seconds.
Good Luck
steviej
Jonny
