Final step in getting to cam seals.. 250lbstq not enough
Doing the TB job in its entirety. Used a chain wrench, some serious 'engineering', and a heavy duty torque wrench and the crank nut came off at about 180lbs of tq I'd guess, wasn't hard, did it with no help.
However, I locked the cam pulleys from movement and put some serious torque on the nuts without any success. There is no specific directions for this that I can find in the write-up or searching here or the LS4 forum. I need to replace those cam seals and resync the timing to make sure everything is good before taking it farther apart to replace the tensioners, idle pulleys, and WP.
Thanks for any assistance, looking foward to getting this damn thing on the road.
Htle83
11-13-23 03:58 PM
cohomology
11-08-18 09:31 AM
