oil changes
A lot of us (I'd venture and say MOST of us) use sythetic. It runs cleaner and longer, and withstands higher temperatures better and starts flowing much quicker than conventional oil during cold starts. Do it. Just be sure that once you make the switch, you don't go back to conventional without changing all the seals, or you will have leaks up the ****.
http://www.cartalk.com/content/colum...anuary/06.html
http://www.whatprice.co.uk/car/synthetic-oil.html
I have 2 friends, one who has an SC, who used synthetic oil through 3 oil changes, switched back to conventional and had to replace several seals to fix leaks. Same problem with another friend of mine who has an older Impreza. I do listen to CARTALK on NPR from time to time, but I suppose it will have to do with age when switching. Both cars that experienced this had 100k+ miles before the initial switch to synthetic.
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
Synthetic user here, switched at 2,600 and I won't be able to check for seal leaks cause I'm not going back. This engine has the sludge potential apparently but I really just switched for long-term engine life.
sktn77a
RX - 1st Gen (1999-2003)
08-19-05 10:23 AM
