quick question
I have a 99 ES 300 and was wondering if the trani and diff share the same fluid. If the trani level is sufficient is the diff fluid okay?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Yep! You got it.
Flush it every other year, or drain the transmission pan every oil change/every other (Depending on what oil interval you're running). & you'll never have a problem with it.
Throw an extra ATF cooler on the thing & seriously, you won't ever have a problem - hah!
Super Moderator
On my 99 RX (we share an almost similar 1MZFE engine), the ATF cooler (that came with the towing prep package) goes under the passenger side headlight.
