Power Window Motor?
Old 04-03-06, 05:44 PM
LexusDaisy
LexusDaisy's Avatar
Default Power Window Motor?
Car is a 96ES.
Front passenger window motor is weak. Nearly stops half way up, and not nearly as fast as the other windows. Is this a motor, or something mechanical binding? Window is a little sloppy in track, but so is driver side. I had to replace window switch last year, but this window was weaker than the others before that.
Anyone ever fix a similar problem? How much?
any advice appreciated. thanks
Old 04-03-06, 09:01 PM
koolaidman
koolaidman's Avatar
Originally Posted by LexusDaisy
Car is a 96ES.
replace window regulator
Old 04-04-06, 05:55 PM
LexusDaisy
LexusDaisy's Avatar
What is a window regulator? I never heard of it.
Is it electronic, or something mechanical. About how much to fix?
thanks
Old 04-04-06, 06:58 PM
koolaidman
koolaidman's Avatar
thanks
aka window motor. thats what they are called at lexus
window all the way up
tape window to upper part of door
remove door pannel
remove 2 10mm bolts from window track
unplug connector to window regulator
remove plastic
there will be 10mm bolts that hold the regulator i want to say arround 6.
pull out
and fallow steps backwards
provided u got a new regulator
Old 04-05-06, 06:14 PM
LexusDaisy
LexusDaisy's Avatar
Is it hard to get door panel off? Sounds like I can handle the window motor swap.
Know of any instructions how to remove door panel on CL?
Is motor Lexus specific, or same as Camry?
No Lexus dealers in my area; anyone else sell the regulator?
thanks
Old 04-05-06, 09:33 PM
koolaidman
koolaidman's Avatar
thanks
its not hard
10 screws at most. need to take out the master switch there is a screw there. 1 in the vent tube 1 near left middle look a lil bit low and 4 more (maybe) on the bottom
Dx3
11-22-13 07:03 PM
Sunny_Tk
SC- 1st Gen (1992-2000)
11-13-13 03:49 PM
dinkel41
08-28-12 10:28 AM
icepanthar
01-06-09 09:57 AM
Quick Reply: Power Window Motor?
