does the sc300 need premium gas?
Old 04-05-06, 11:59 AM
LazyAlex
LazyAlex's Avatar
Default does the sc300 need premium gas?
ok well..i know the gauges say "premium unleaded only" and so does the gas lid...but is that what they recommened? or what it needs becuase...premium here is $3 a gallon.,..and ya..thts $$..so i was just wondering..i mean..i been pumpin premium..but..if it should be ok to pump regular..or plus..ima start doing that..till gas goes down alittle..any idea? thanks
Old 04-05-06, 12:03 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Lexus V8 need premium.
Salim.
Old 04-05-06, 12:05 PM
LazyAlex
LazyAlex's Avatar
Salim.
what about the sc300 V6? does it NEED it? or just recommened..so plus/regular will be fine?
Old 04-05-06, 12:06 PM
Din
Din's Avatar
yes it does and its not a V6. its Inline 6.
Old 04-05-06, 12:09 PM
LazyAlex
LazyAlex's Avatar
yes..sorry..inline 6..thanks
Old 04-05-06, 12:19 PM
DuncanC
DuncanC's Avatar
Default V8 Gas
You don't have to run premium but for the little extra it costs you'd be crazy not to. The engines automaticly retard the spark timing if you run crappy gas. Less power. Way worse fuel milage. Highway driving in my SC400 I get about 15% more miles out of the same amount of gas if I ran premium.
Old 04-05-06, 12:31 PM
MongooseGA
MongooseGA's Avatar
Buying things like premium gas and little bits of maintenance and repair are what kill people.
Some people can afford to buy the car, but can't afford to own the car.
You bought a Lexus which reccomends using premium fuel for the best performance and efficiency. Just use premium and accept the costs that come with a high end car.
Old 04-05-06, 12:37 PM
VJ RC51
VJ RC51's Avatar
I ran 87 and always got better fuel miledge. its not like you'll break the motor, the ECU will retard the timing if need so.
the only time ive seen better fuel miledge with a gas was running 100 octane oxygenated fuel.
Old 04-05-06, 02:11 PM
SUPRMSC
SUPRMSC's Avatar
91 and up for any lexus period.
Old 04-05-06, 02:15 PM
STRONG SC
STRONG SC's Avatar
91+... gotta pay to play!
Old 04-05-06, 02:17 PM
kylessc400
kylessc400's Avatar
the highest octane we got in my town is 92...so thats what i run...i had to run the same gas in my 93 BMW......i dont know if it gets me better gas milage but my car runs alot smoother with 92...
Old 04-05-06, 02:30 PM
Stoic
Stoic's Avatar
Sorry to be off topic a little but hey Din. Did you put your car on ebaymotors a whole back? I swear I saw your car on there not to long ago..
Old 04-05-06, 02:44 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Actually it does harm the engines... after prolonged usage of 87 octane on the V8 (in particular) leads to the destruction of your knock sensors, which are $2xx something dollars each, yes you’ll need 2. Then the labor of having to remove the whole intake manifold to get to the 2 sensors...for a pro it’s a minimum 2-hour job. It could take hours for someone who doesn’t know what their doing.
And finally when the sensors go bad and u don’t replace them they will no longer tell the engine to “retard” the timing and thus you begin (and its not anything that will happen with in a day, it will take time) to slowly mess-up you various engine components....
In your case you’re running a 1jz so I can’t and won’t talk about that because I really have no idea about those engines. But with the mechanical knowledge I have and with the time I’ve spend working on the 3 Lexus V8s we have in my house, I’ve learned a few things….
In my opinion if you want to drive a lex don’t be cheap, pay the extra 5 bucks a tank… If not there’s always civics and even better mopeds u can drive…you can ever put a ½ oil 1/3 gas mixture in those.. and this is not pointed towards VJ RC51.. hes doing his own custom stuff that I give him props for.. these are for the guys rollin a bone stock SC's and cant aford the gas
Old 04-05-06, 02:53 PM
VJ RC51
VJ RC51's Avatar
Yeah well the 87 in the tank was for the 2JZGE.. the 1JZGTE i feed it 93 octane because i always romp on it, but if i knew i'd have an easy foot, running 87 octane in the 1JZGTE would be no big deal at all, as long as u dont run 10psi for extended periods of time or even really use boost. Remember off the blurbo its a low compression motor.
i used to run 87 octane in my grand national ALLLLLLL the time when i drove long distances. I would change chips to a stock chip and run 8psi of boost. When i needed power again id switch to my performance chip and 93 octane and run 20psi.
I drove it from florida to maine non stop on 87 octane, no probs.
Old 04-05-06, 03:11 PM
sprucegoos
sprucegoos's Avatar
Many people who buy used premium luxury cars don't realize you have to pay a premium price for maintanance on these rides. If you want low prices stick with econmy cars. If you think premium gas is high for these rides wait until you have to replace your lca's for a premium $1G +
Quick Reply: does the sc300 need premium gas?
