Huh? $195 just to change the spark plugs?
Old 04-07-06, 11:37 AM
jtgs400
jtgs400's Avatar
Default Huh? $195 just to change the spark plugs?
I got quoted for $195 just for the plugs. It's another 2 something for the cap and rotor. Is it really this much? I think it's a DIY with the plugs running only running around $80-90.
Old 04-07-06, 12:21 PM
AZDesertGS
AZDesertGS's Avatar
There's a cap and rotor for the GSxxx??? Do the plugs yourself.....there is plenty of info on CL that will help.
Old 04-07-06, 12:31 PM
GSteg
GSteg's Avatar
There are no cap/rotor on our GS4's. We have a distributionless system with coil packs. Changing the plugs takes less than an hour to do. Then again, dealers will probably want $100 for the plugs, and then $95 for labor (takes about an hour sometimes, for them. lol).
DIY is better in terms of money saving.
Old 04-07-06, 02:18 PM
Tammy
Tammy's Avatar
Aluminum Head -
Use “Never-seez®” grease 14-20.5 Ft Lb (wet)
(Steel Crush Washer – New - Ratchet 90 deg after finger tight)
(Steel Crush Washer – Used - Ratchet 30 deg after finger tight)
Old 04-10-06, 09:57 AM
b1gredek
b1gredek's Avatar
get the plugs at toyota,,,,,, same plug,,,,,,,, different price,,,,
Old 04-10-06, 03:06 PM
TexasGS
TexasGS's Avatar
Originally Posted by Tammy
Aluminum Head -
Are there crush washers on our spark plugs? Are they recommended? I know we have them on some of our fluid drain plugs.
Old 04-10-06, 07:52 PM
Tammy
Tammy's Avatar
Crushwashers are preinstalled on the plugs... Japanese plugs anyway.
Old 04-10-06, 08:02 PM
nthach
nthach's Avatar
Plugs on all non-distro baseds 1UZs should be Denso PK20R-11
coil-pack based ones are Denso Iridium plugs, IIRC IK20R-11
Old 04-12-06, 01:40 AM
Lexmex
Super Moderator
Lexmex's Avatar
Sounds like the price for changing out the RX plugs, luckily my uncle and I do it ourselves.
Old 04-12-06, 10:15 AM
bob2200
bob2200's Avatar
If you keep the car for 200k-mi and have to spend $200 to change the plugs once (at 100k-mi or so), that doesn't sound too bad to me. It's down in the noise compared to the other maintenance expenses, not to mention gasoline.
kaloman
05-22-20 09:18 PM
janmy7
10-23-12 04:34 PM
edgeucated
03-23-10 01:35 PM
southtrian
Maintenance
04-13-06 11:05 AM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 08:19 PM
Quick Reply: Huh? $195 just to change the spark plugs?
