costco gas
gas in my area is !!!!!!!!!!!!!!!! I've noticed that Costco gas is about 10cents cheaper than everywhere else but I've never used it before. Has anybody had any experience using Costco Gas before? How does it compare to 76 or Chevron?
No Sir, I Don't Like It
Costco gas is just like Sams gas, its just as good as everywhere else, only cheaper
....hope that helps. I usually fill up at Sams, but now everywhere gas prices have been jacked up for no reason its rediculous. almost 3.00 a gallon here again.....(premo of course)
I'm just asking because I've used quite a few different gases and I've noticed offbrands such as World, etc... to give me lower mileage and kind of rough driving/idling.
Arco gives me lower mpg
the best that I've used is 76 which runs smooth and also gives me the best mpg
Chevron gives me equally good smoothness as the 76 but a little lower mpg
There's no Sam's in my area so I wouldn't be able to judge. And I don't have a Costco card yet so I can't go test it yet. I was planning to get one and if Costco gas is pretty good, this will motivate me to get it faster! haha.
I've noticed the roughness also. My understanding is that Costco, Sam's and other discount gas brands are pretty much regular gas but without the detergents and special additives the big names (exxon, mobil, chevron, etc) put in theirs. I've had to pour in some fuel injector cleaner evry now and then which negates the cost savings I otherwise got. I've gone back to Sunoco and Shell mostly and only use Costco gas every now and then.
i've been using costco since last june and haven't noticed a difference or had any problems. i go there regularly to fill up.
the prices inside costco are great as well, so you may as well go ahead and get that costco card.
Super Moderator
I can understand wanting to save $$$.
Being in Mexico, I have no choice with the national monopoly down here and the gas is really bad even the premium.
Once a month, I use the Techron in concentrate format and my RX300 feels much better afterwards.
I too use Costco gasoline (and other discount brands) regularly with absolutely no issues. I also don't use any additives. I trust the Costco gasoline because Costco, as a company, shies away from marketing gimmicks (except maybe with their executive membership, of which I have one!) Note that they don't even sell a mid-grade gasoline--a grade driven by marketing, not need.
I use Shell and Chevron
Both are top Tier Gas
When I used Costco Prem 91 I got 18-18.5 mpg
Using Shell or Chevron 91 I get 20.5-21.5 mpg
The difference in price is more then made up in the mpg, the extra booster packs go a long way.
Here in Douglas County CO the Difference between Costco and my local Shell is usually less then 5 cents a gallon so its a no brainer I stick with Shell.
Use your Citibank credit card at most stand alone gas stations and I get another 5% off (15 cents at $3/Gallon)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
From my experience, I only use Chevron. I used Arco a couple of times and noticed my MPG was lower and the engine wasn't as smooth. I have been using Chevron ever since. My wife always uses Costco gas in her Accord, but when I fill it up with name brand gas I notice it runs a little better and the MPG increases.
