What's the deal with the Water Pump?
As far as water pumps are concerned, as long as you have good maintenance on your car, water pumps don't wear out that often and therefore don't need to be changed. From a cost/service standpoint the price for this service can be costly and there is alot of labor involved., Might as well have him change the timing belt while he's done there since it will be right there in his face. Bottom line, if it aint broke, you don't need it fixed.
I've read about this in a number of threads in the past week (I'm retired). There appears to be divided opinion on whether or not to replace the water pump when you replace the timing belt. One argument is that you have to perform most of the same labor anyway. The counter-argument is that the water pump (if you've been changing the coolant every 2 years) will likely not cause problems. Some have indicated that a good mechanic can look and feel for waterpump problems when he's in there and decide/recommend whether or not to replace on the spot. Don't forget the belt tensioner.
I don't have any personal experience, my car has a long way to go until I get to 90K-mi.
Super Moderator
Originally Posted by Dx3
Guys,
After speaking to Lexus I am curious as to why they do not advise on doing the water pump when they do the 90k service?
Jonny
Jonny
Originally Posted by meZoom!
If your water pump *does* go out later, they can pretty much charge you for labor again.
The newer Lexus engines are interference engine which mean if the timing belt break the valve will come loose and hit the piston. A major engine repair.
Super Moderator
I plan to keep my RX a long time so, when the 90K came around I did the timing belt and water pump...more convenient to do so. Plus, since I live south of the border, I didn't want an issue in the middle of nowhere, even though I could fix it back in Mexico City.
Originally Posted by VVT-i
That's right. The water pump works just like your AC compressor, alternator, power steering pump or fan clutch. It will not last forever, but when the water pump locked up( on the Lexus engine) it will seized up the timing belt cause your recently installed timing belt to break.
If that is the case, why doesn't lexus have the water pump replacement as part of their 90k service? Has anyone here ever had a water pump go out? And if so.. did it cause internal problems on your engine?
Just wondering
Thanks
I was thinking about something similar. Since the 1UZFE engine is a non-interference engine, what would happen if the timing belts were to snap? Does the car automatically protects itself to the point where there would be no problem (minus the timing belt obviously)?
I was always told, interference engine or not, a timing belt breaking while moving that fast will cause some sort of damage in the engine bay.. and i've always had that replaced on whatever car I owned... now the waterpump, i know it can go out, but never heard of it doing additional damage.
...that's because no one has told you that, on a good many of the timing belt failures documented on this forum, it is a seized water pump that tore up the timing belt in the first place.
Super Moderator
I am not too impressed by engines that use the timing belt to drive anything other than the camshafts. When I first saw the engine in the GS300, I was happy that they put the water pump on the alternator belt, but now I see in the service manual that the timing belt has to come off just to get access to the pump. I have no idea why they did that. Taking the timing belt off is a pain.
I once had a Honda that had a water pump driven by the timing belt. The pump bearing fell apart but I shut off the engine before the belt skipped. That happened at about 65000 miles. I have also had several cars where the water pump never failed.
I had my timing belt changed at 90K miles and 180K miles on my 1996 ES 300. I still have the original water pump. As of now I have over 254K miles on the odometer. I will change my timing belt and water pump at 270K miles. At this point I'd rather be safe than sorry...
Changing the water pump is part of the 90k service at my local Lexus dealer. I'm getting my 90k service done in a month on my GS400. This was also part of the 90k service on my old 95 LS400.
Who ever said it wasn't part of the 90k service??? I guess different dealerships recommend different stuff???
Jonny
