windshield washer failure
I have a 93 SC400 w/ 225k.
Winshield washer recently failed then worked again then failed. Wipers are still activated when washer button is depressed.
Anyone have a clue?
John
Anyone have a clue?
John
You may has bad washer pump/motor goes bad. The motor is located at the bottom of washer reservoir, but check to see if you have 12 volts going to the motor when you activate the switch.
is250gurl
08-22-08 08:22 AM
