Lexus 90k Service for 99 GS 300
I assume the timing belt , water pump, thermostat and change all the fluids will be done for $1,300.00. I will break it down as $450.00 for a 90K service without spark plugs because 99 GS spark plugs due every 60k and $850.00 for timing belt, drive belt and water pump. This is the same price here in Atlanta( I'm sound like Lexmex everyday...lol...j/k Lexmex...
hmm they use those NGK plugs right?
and i gotta get an oil change also so how much would that be?
also i think my starter is gone and on the gs forum they told me thats bout 300 so combing all these would make labor cost less correct?
Originally Posted by suprropmp
how can you tell if your starter needs replacing?
You'll hear clicks, but no cranking.
Or sometimes you just know it takes a lot longer to start up the car, like in my case. I had to replace my starter. Thank god I did it before I took a long vacation. lol. I use to be so paranoid about starting up the engine. I would basically pray each time
Originally Posted by GSteg
You'll hear clicks, but no cranking. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
After the starter replacement, it is such a relief. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
got stuck downtorn and at school...
horrible.
LS400UCF20
12-19-16 06:02 PM
