ticking in back motor on drivers side
i seen alot of threads with this prob is and they say it a value that needs to be adjusted is there any oil to put in to make the ticking stop thx for help
https://www.clublexus.com/forums/sho...d.php?t=210076
Sound like you need a valve adjust on the driver side,but make sure that's the problem. You can use a long screw driver/long metal object and place one end at the suspected area and one end on your ear. A valve adjustine job at the dealer will cost you around $300.00-500.00, most of the cost are from labor to remove the valve cover, check and use proper shim to adjust the valve clearance. A lot of time consuming.
can i do this my self is there a site where they show u step by step and whats a shim???
My first car had no valves to adjust ('65 Saab 2-cycle). Next two cars had valves that you could adjust with a wrench and feeler gauge, and in the case of one, you needed two specially shaped wrenches ('71 VW and '72 Mercedes-Benz). Back in those days, cars that used shims were looked down on, but times change.
