losing coolant
so the ES250 is losing quite a bit of coolant. i thought it may be a bad head gasket so i checked for bubbles in the rad when the pump is running...no bubbles to be seen.
the water pump is new. the rad is relatively new. it doesn't seem to leak on the parking spot too badly. there are dark dots on the parking spot. i assume it's a bit of oil.
the exhaust has always smelled pretty odd.
where am i losing coolant?
i notice the engine knocks a bit on idle.
Check your heater hoses for seepage and wear. Sometimes they drip down on exhaust manifolds or pipes.
(Coolant hoses go bad from the inside out).
Inspect the spark plugs for white coolant contamination
Check the compression in all cylinders, they should be within a 5 psi range
Check the heater valve for leakage.
Check the seals on the pressure cap for cracks or wear in the rubber.
Have you serviced the anti-freeze/coolant lately?
i heard that adding a raw egg to the system works wonders. it should be added when the engine is at normal temp.
Originally Posted by koolaidman
also check ur oil level. and check to see if its milky if it is its the head gasket
Adam0412
01-25-13 12:16 PM
