wheel bearing
Hi all, i need a rear right wheel bearing for my 98 lexus es300. I heard that this part is the same as the 98 camry. Can anyone confirm this? Also i tried calling the lexus dealership to get the part number and match it with the one given to me by toyota but they said they don't give out part numbers which i think is retarded. also can anyone confirm the part number that i need. thanx
I'm sure it is the same part # with the 98 V-6 Camry rear wheel bearing.It's not hard at all on the front wheel drive car like ES. You have to remove the rear brake rotor. The new wheel bearing will come with the hub and wheel studs. On the hub you will see one big openning hole, you will use that one to access the bolts that hold the wheel bearing to the knuckle.
