What is the correct ballpark range for R134 recharge?
Does anyone know the proper pressure for a 92 sc400? Right now, I have it at about 35 psi on the guage (middle "blue" range). I have searched and read several threads about it, but I'd like to know what the proper pressure is supposed to be... i read somewhere 40 psi, but I'm not sure..
Thanks, all!
Thanks, all!
I believe you converted your 92 SC to R134,correct?. It will take about 1.4lb to 1.5 lb.
Your low side pressure should be around 28-35 psi. Your high side pressure should be around 150 psi.
