Bar's Leaks Products Any Good?
Old 10-10-06, 03:58 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Default Bar's Leaks Products Any Good?
http://www.barsproducts.com/
For use in a '93 ES300 with 400K Kilometers on it?
Specifically for Engine, Transmission, Power Steering leaks.
Thanks,
Lexucan
Old 10-10-06, 05:19 PM
koolaidman
koolaidman's Avatar
its jsut for temporary fix. almost better than using an egg in ur radiator
Old 10-10-06, 05:35 PM
Max707
Max707's Avatar
Worked pretty good in my 95 LC's power steering.
Old 10-10-06, 05:52 PM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
I have heard it, but for engine and tranny would suggest, http://www.auto-rx.com
Also, check out www.bobistheoilguy.com for a lot of information on additives.
Old 10-10-06, 10:45 PM
nthach
nthach's Avatar
The original Bar's Leak is just ground ginger root. Good stuff that should be added as a prohylaxis on American cars like GM and Ford products - as they add and sell Bar's Leak under the AC Delco and Motorcraft label. Don't need it on a Toyota or a Lexus product, unless you love clogged radiators and heater cores.
Old 10-15-06, 05:53 PM
PRSUIT460
PRSUIT460's Avatar
It's not the right way to go about fixing a problem. Will it work? Maybe and temporarily.
Old 10-28-06, 10:21 AM
HELLAFLUSH
HELLAFLUSH's Avatar
Thats a bad temporary fix. Fix it right.
Old 10-28-06, 02:24 PM
toy4two
toy4two's Avatar
The longest I've seen it last in a radiator was 1 month. My friend had to add it every 4 weeks to his Corrado. Just replace the broken part.
Old 10-28-06, 11:54 PM
cowdung
cowdung's Avatar
In a word, NO. It does more harm than good.
Old 10-31-06, 02:35 PM
platinumLS
platinumLS's Avatar
Thanks,
Lexucan
im sorry to go off the subject but does ur car really have 400k on it??????
Old 10-31-06, 05:56 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Actually, no.....it's closer to 408,000 but I rounded it off.
The water pump has developed a minor leak recently which I am trying to hold off fixing until I get the car's third timing belt replacement done. For a 13 year old car with that many kilometers on it, it runs extremely well.
Old 11-05-06, 09:31 AM
Rice
Rice's Avatar
Do not ever put any stop leak products into your car!
They may stop the leak, but they will most definately clog other vital components and end up causing more costly problems.
Just because they sell it, doesn't mean that you should use it.
Thrive1987
09-08-18 01:42 PM
AndyG
02-09-14 03:07 PM
98silvgs
10-30-12 12:27 PM
Brando
06-30-05 11:13 AM
Quick Reply: Bar's Leaks Products Any Good?
