SRS light on - asfter dash removal
I removed the dash to fix a sticky speedometer.
Checked by turning ignition on.
Now SRS light stays on - so at least I learnt the computer logs the wiring! - did not fix the sticky speedo
So, how do you reset the error code?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
You probably stored a code from turning the key on, while the combo meter was unplugged (code 22, warning light circuit malfunction). Everytime you start your car the airbag ecu does a self diagnostic. It saw that the warning light was not functioning, so it set a code. You'll have to take it to the dealer to reset. Unless you know how to clear it the old fashioned way. Or have your own reset tool.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
i just purchased a 1991 lexus ls400. i've found a 1990 lexus ls400 that i want to get for spare parts.. will most of the parts from the 90 fit the 91 ?
