Need Labor Times? or help from Mitchell Repair???
#33
Man, all of that is standard services... Inspection of everything should hopefully be free or extremely cheap. There is no labor time for inspection of those. The Cabin air filter (a/c filter) labor should be around $20-$30, brake flush should be around $90, oil change depends on weight of oil, and the only other thing on there worth noting price is spark plugs... which car and motor?
#34
Can you give me an idea of the cost and/or hours to rebuild an automatic transmission on a 93 SC300?
Im trying to decide wether to order a performance rebuild kit wich is $585, and have it installed locally, or a BL tranny for 1800 + shipping and R + R cost.......
-Thanks
-Thanks
#35
-Thanks
-Thanks
#36
Hmmm, I didnt realize it was quite that labor intensive.......Apparently im looking at 2-3K with either of those options then......
I really didnt want to tackle the tranny R+R in my garage , But i should just go ahead and chance it on a used Soarer tranny , and just install it myself .......
Anyhow, Thanks alot for the info
#38
I work as a sales manager at a vehicle repair shop (in Las Vegas). I have some free time during the day, and wanted to offer this free service to all CL members...
Basically, I can look up just about anything in Mitchell, Dealer list pricing, Labor times, wiring diagrams, even troubleshooting some issues. It also has preferred fluids and quantities.
If anyone has a request, post it here, and I'll get back ASAP...
For instance, if you have a 93 SC400, and you need the rear main seal replaced, I can look up and see that it lists:
5.5 hours labor (includes R&I trans/transaxle)
Part # 90311-A0002: $27.09 dealer list
and if needed, the oil seal retainer is part # 11381-50020: $74.83 dealer list
Certain parts I can get exploded view diagrams and post as well...
Keep in mind these prices are subject to change, but it's a good starting point so you know what the dealer should be thinking when you get there... (I liken it to knowing the book value of a car before talking to the salesman) Also, certain parts have labor times and warranty times, in which if it's under warranty, it's charged less labor time for some reason.
#39
MS is the 2.6 Hour Quote for replacing the Rack and Pinion on a 94 LS400 still current or can you tell me what an independent shop should be charging; think I am going to purchase a Reman R&P and have them install it? Recommendations are appreciated? Thanks for the response
Careful before you buy a part, some shops will not install parts they don't sell... And also, just a warning, if you get a reman unit, and its defective, even if it is right when it is first installed, the shop will charge another 2.6 hours to swap to a different rack, whereas if they buy the part, they would eat it if that were to happen... Just a thought
#40
Hi I'm searching for labor time called for replacing the following items on a 98 gs400. Thanks
power steering pump
alternator
L/R motor mounts
transmission mount
power steering pump
alternator
L/R motor mounts
transmission mount
#42
Not sure if this thread is still active, but how much labor is involved in replacing the steering rack assembly on an '05 RX 330? Any help is appreciated, this was/is a great thread!
#44
Thanks for the quick reply. This kind of information is invaluable, so thanks again for providing it. Do you know of any reputable shops in Las Vegas that work on Lexus? I thought your first post said you worked in Vegas, but now you are in Mizzou?
#45
I worked for Ted Wiens out there, as with any place, your experiences will be more directly related to who you are dealing with directly, however, when I was there, they ran a fair operation with pretty knowledgeable guys...
I am now in Missouri, yes...
