Need Labor Times? or help from Mitchell Repair???
#46
OK, I have used Ted Weins for tires and oil changes over the years and been happy with them. Thanks again for the info, I'll be using this forum again in the future, I'm sure! Have a good one
#47
I have a 1995 sc300 needing a water pump (timing belt already replaced) and a power steering pump. Please tell me approx price for parts and labor, if done in a shop. Thanks : )
#48
Dysfunctional Veteran
For the waterpump, Anywhere between $900 and $1400 is reasonable...depending on the shop rate. I wouldnt pay any more than $1400 though. Sometimes you can find places that will do it for less than $900. Power steering pump, I am not sure, I would say between $400 and $500.
#49
If you have done the timing belt, well then you can add about 150-200 on top of that for the water pump.... the belt has to come back off to replace the pump and replacing the belt again might be recommended, unless it was literally just replaced.... this, fyi, is why we recommend to do the water pump at the same time as the belt... power steering pump labor is most likely an hour or a little more - its pretty easy, though the drive belt does have to come off,, just as it does to get to the timing belt.... I will get exact labor times for you shortly....
#51
Thanks for your reply. I knew it would be expensive. What is your opinion on Blue Book (and other) values? What I am getting on my searches is that the car is valued between around 3800 to 5000, depending on condition. These values seem low to me, especially since these cars are hard to find. The car needs those 2 parts and a paint job because there is wear from tree sap on the roof and hood.
#52
Thanks! Definitely not cheap to fix. I have been looking at blue book and other values. They seem low to me. The range is from around 3800 to 5000, depending on condition. The car needs these 2 parts and new paint because of tree sap on the roof and hood. Since the car is not easy to find- seems like values are too low.
#53
If the rest of the car (interior) is in 100% working order and in excellent shape, I could see spending $3000 on the car, cause I can find ones that need work for $1500-$2000 all day long...
#54
Don't know if my reply got sent before- computer issue. The car does need interior work: not too bad but parts of the leather are cracked and torn, 1 door handle missing, air bag light on. Sounds like not worth fixing up to sell- only worth it to keep as another project. Wonder what I can get out of it as is- sounds like the 1500- 2000, sad to say.
#56
Wow this thread is awesome and you've had it going for years. Thank you!
I'm not sure what you can look up but how much would a full interior install cost? New seats, headliner, carpet, dash, center console etc. I'm not sure if that would even be there. Thanks!
#59
here ya are:
https://www.clublexus.com/forums/sc-...y+dash+removal
#60
Here is some more help then... Saw in the other thread you have a SC... I did a step by step dash removal on my older SC... lemme see if I can find the thread...
here ya are:
here ya are:
