Do you follow the 3 month/3k mile oil change?
#46
#48
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
It depends on how you drive it, simple as that. If you beat on it around town, start it and go first thing in the morning to go somewhere within walking distance, stick w/ 3K. If you baby it, run synthetic oil at the recommended weight, keep it tuned up (tire pressure & wheel alignment also) ONLY then can you go with 7K at the most but if its leaking oil, keep an eye on the oil level as you run the chance of running the engine with low oil longer, obviously. And dont use fuel additives either they dont do anything besides foul plugs and injectors. Use only Marvel Mystery Oil every other oil change or so, dont go crazy. If the oil is black, change it regardless of mileage, and if its black and youre still in the 3K window, stop beating on your car. I use trip A for LOFs and trip B for fuel mileage, also
#49
ocular inspection is sufficient.
#51
Hey, why not change this virgin oil since it is already darker than honey dyed oil, it must be toasted already!
![](http://home.comcast.net/~dsmphotos/gcdial/3.jpg)
FWIW, here is a link to those who wish to learn what is oil analysis
http://www.bobistheoilguy.com/whatisoilanalysis.htm
#52
How about the amount of acid fighting additive, viscosity, fuel dilution in the oil. Oh, I forget when the color of the oil is black, it is time to change the oil! It will definitely tell you TBN is low, oil is thinned out and has abnormal amount of fuel.
Now, where did I place that Yellow Sunshine!
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#53
I have never and probably will never have a UOA done...
I just don't see the point in it...
I figure what I've been doing in my cars (following manufacturers intervals, or better) has worked for 11 years of driving, a variety of different cars (everything from a 74 MB 450SL to a 500whp 2 liter Talon), and never once have I had an oil related failure... The Talon survived the 500 whp level for 10,000 miles and it was bone stock with 160k on the motor when I purchased it...
My current lexus has close to 190 on the clock, doesn't burn a drop of oil, and I beat on it everyday, in dry Vegas heat nonetheless...
Now, could I extend my oil change intervals, maybe, but how many UOA's would I need to do to figure that out? I'd rather just change the oil and be done with it. Could it alert me to a coolant leak, sure, but you can do a block test at a local shop for $10-$20 that will tell you the same thing in about 30 seconds, or just pull your dipstick, or look at your drained oil and will tell you the same thing...
#54
Ever have a annual physical check and the nurse draw blood to send to a lab? A clean bill of health is given after an analysis is done. Is it required to have a good health? No, you can just flat out tell the doc that if you look all right from the outside, that is all he needs. After all, it is your health right?
#55
My gosh, if you ever use Royal Purple, that oil is even worse looking, it is purple and sure look darker than green. By default, RP oil is worse than Castrol Syntec 0w-30 straight out of the bottle!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#56
how about fuel dilution or air filtration? How can you eyeball dirt getting into your engine?
People have hobbies, I can get an oil change and a lab analysis for $25. Most people pay more just for an oil change, I on the other hand can enjoy both an oil change and know the health of my car. It helps me sleep better at night jednav.
#57
#58
#59
Now, that will add years to your life.
#60
Go with what the owners' manual states. Auto manufactures have spent $$$ and R&D to come up with their recommendation. I would take their recommendation over any dealership or lube shop trying to get you to switch earlier. As someone stated earlier, oil analysis will tell you a lot about the condition of your engine and oil and if you need to change earlier: I use BlackStone:
http://www.blackstone-labs.com
