45k service- Dealer or Independent Shop
I have a 2003 GS300 and my 45k service is coming up. I called a couple of the dealers here in Houston and they want $500.00 for this!
Would you guys recommend me spending the extra money and going to Lexus, or should I use an independent shop? I think that an independent shop would cost about half (~$250.00).
Your suggestions are appreciated. Thanks.
You can do it either with the dealer or independent shop, whatever you feel comfortable. But one thing that I've learned after in this business for a long time. The car that service at dealership get top dollars on the trade in or private sale,because you can say " All services done at dealership, will provide the print out". A few hundred dollars more you spend at the dealership will pay itself when you want to sell your car.
One more thing, you build a relationship with the dealership and when your car is out of warranty and there's something goes wrong they may do it under the goodwill gesture.
Guest
Posts: n/a
In all honesty in my experience, even with non Lexus cars, outside the basics like oil changes, the dealer is not much more expensive than an independent shop.
JPI
Guest
Posts: n/a
Great points.
Its about establishing a relationship with the dealer. A lot of times when you are a repeat customer, they will look out for you, give a discount, no haggle with loaners and Lexus has the 1 yr warrenty on what they worked on. Also piece of mind that you know the job was done by certified techs.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Odds are that will likely be the last Ford product I'll own.
If you use an independent shop, and your car is under warranty, just show proof you had the service done. I have come to understand that the relationship you have with the dealer is only as good as the personnel at the dealership at that time. Once the management changes or the S/A has moved on, you are on your own! I have many years at 2 Lexus dealerships and can speak from experience that, if you take care of your car, under the guidance of the owners manual, your car will last a quite a while.
The money you will save in using an indepenent shop will overshadow the expense, by far, of replacing a major component over time!
Yes, I was a dealership employee. Yes, I have opened a private Lexus repair shop in the Houston area and yes, I have an interest in growing my business!
I would, and still do, take good care of my customers that were clients of the dealership. And If I was still at the dealership, I would take care of them now! Thats my point....
If you are in the Houston area and you need advice or service/repairs, give me a call, I would be happy to advise you or help you!
heidihidin
Maintenance
12-22-23 08:49 AM
LexusMan77
09-19-10 08:53 AM
