Remove Oil Pan 2003 GS300
I posted in the GS2 forum that I dented my oil pan. I would like to replace the lower oil pan and possible the baffle and the oil pump if they are damaged in any way. Could someone with access to a manual post procedure to remove lower oil pan and hopefully have diagram/pictures of where the oil pump and such reside in there? Thank you!
Link to my damage with pictures...
https://www.clublexus.com/forums/sho...d.php?t=277819
http://sr1.clublexus.com/forums/showthread.php?t=276491
This guy selling his oil pan in the classified section...
I don't worry about that little dent on your oil pan. I've seen worse damage oil pan than this one and the owner just don't care as long as it not leaking oil...
If you want to replace it that's fine,but hardest part is to get to the bolts that closed to sub-frame. You will need 1/4 inch swivel 10mm socket to get into the tight spot and a tube of Toyota FIPG for oil pan.
Your oil pump and oil pick up screen should be o.k. The oil pump is behind the timing cover and it part of the front part of the engine( a very big job).
