Question about changing frt. brake pads
I'm going to change the factory pads on my IS350 to some Satisfied ceramic pads. I only have 3200 miles on the brakes. Question is can I just crosshatch sand the rotors with some 220 grit or should I get the rotors turned? Thanks, Jimmy
Super Moderator
Of those 2 options, get the rotors turned.
Once you have the rotors off, in the Los Angeles area, you can find places to turn them for as cheap as $8/rotor. If you didn't do much hard braking in the past 3200 miles, you can probably get away with not turning the rotors either, if you *must*
you have GOT to be ****ting me... I have never turned a set of rotors... I work at a shop that does brake work... 98% of people, I say turn rotors... Performance applications with no grooving of the rotor and no warpage of the rotor, I say sand em and slap the pads on (so long as they are still thick enough)...
On my own personal vehicles, if a rotor is bad enough to need turned, I just replace it...
Turning rotors in a performance application just means less material to disappate and absorb heat... not something I recommend for someone who really cares about performance...
So, to the OP, so long as they are not grooved or warped, sand em down and slap the pads on...
Super Moderator
You say 98% of people turn rotors, yet tell the OP to sand them instead.
You also don't recommend turning the rotors for someone who cares about performance due to the heat dissipation concern, but the OP does not specify that they are for performance (the term "performance" in my definition implying track days, canyon driving, general racing, etc where heat is a true concern). The Satisfied ceramic pad compound implies that the person is looking for a mild upgrade in stopping power over the stock pads, probably since Lexus OEM mainly focuses on noisefree and dustfree issues, not necessarily superb braking ability. Day to day city driving does not generate the speed (hopefully not) or heat to the brakes that would cause a true, serious concern in regards to heat buildup, unless you are one of those people who have their left foot compulsively stuck on the brake pedal while driving. The shop manuals will instruct to turn the rotors as opposed to sanding them. On the rear rotors, sanding is ok per many oem manuals. I took this thread to imply the front rotors specifically.
I work at a shop as well. For customers with stock or stock replacement rotors, they get turned. For performance rotors (mainly cross drilled), they are sanded or frequently replaced. I mentioned that if he/she "*MUST*" ("MUST" being the key, important term), then they can get away with not touching the rotors and just swapping pads, but not that that was the recommended method. Yes, it'll be nice if everyone could afford to replace their rotors every time they needed turning, but not everyone does. On an OEM rotor, it is perfectly fine to turn rotors (sanding is ok too, but not my choice, specifically given the 2 choices). If heat and performance are such an issue, I'd be using upgraded aftermarket rotors anyway.
PS-don't forget to break in the pads as well. good luck.
I told the OP to not have the rotors turned because, judging from a mild upgrade in braking performance, that heat dissipation might be an issue - if he is not happy with stock after only 3000 miles, then he is more than likely looking for a performance increase...
IMO, turning rotors is going to slowly die off... many cars today come with non-serviceable rotors that MUST be reused or replaced, not turned. If there is no reason to turn a rotor - ie grooving or warpage, then don't turn it...
I'll try to find an article that reinforces this, out of Master Mechanic publication and post it here...
Here's the entire article from Master Technician:
Bye, Bye Brake Lathe?
By Bob Freudenberger
Not quite, but there’s definitely a trend toward replacement.
Here’s why...
Our brake lathe went in the trash,” a Mercedes-Benz service manager tells Master Technician. A veteran brake trainer says, “Within the next five years, you won’t see a brake lathe in a shop.” A successful Euro car specialist tells us, “We’ve gotten rid of our brake lathe. The tolerances on late models are so close, any appreciable wear demands that the rotors be replaced.”
Yup, fewer and fewer professionals in the auto service business are machining discs. They’ve sworn it off in favor of buying new ones. Now that’s a profound change considering that it wasn’t very long ago when every shop in the galaxy automatically turned rotors during a reline providing they weren’t already down to their legal throw-away thickness. That process was supposed to give a nice, fresh face that would break in along with the pads. Well, as Greg McConiga, former NAPA/ASE Tech of the Year and honored colleague at MT, puts it, “We need to take a stand on the old ‘turn ‘em every time’ baloney and tell them that if there’s no runout or DTV (Disc Thickness Variation), and if they’re thick enough, you can’t beat a work-polished rotor surface.”
Early Glimpse
We were tipped off to this trend way back in ‘97 by a Pontiac TSB. During normal pad replacement, it said, use the discs as-is providing the grooves aren’t deeper than .060 in. If those concentric furrows exceed that limit, replacement is the remedy. And in high-pedal-effort situations, GM wanted you to buy new rotors if the originals have ever been turned. In essence, the biggest carmaker in the world was telling us brake lathes are obsolete.
It's not likely that you'll be machining futuristic discs like this fiber-reinforced ceramic composite SLR McLaren specimen (courtesy Mercedes-Benz).
Obsolete? Providing you do what's necessary to achieve a fine finish, not necessarily.
Blasphemy and revolution! But there were two good reasons why this bulletin came down from on high. One, rotors have gotten pretty skinny, and the thinner they get the less able they are to absorb and dissipate all that heat, and to withstand warpage. As one brake company tech trainer tells us, “I agree with the GM recommendation that if the rotors aren’t in bad shape and there’s no complaint, why refinish them? There isn’t a whole lot of extra meat to take off today.” While the notion of “hanging pads” might be offensive to your sense of craftsmanship, just get over it.
Two, noise and hard pedal complaints and prematurely worn-out linings are very common with some of the brakes out there (the big company was having lots of trouble with friction formulas in those days). The factory service engineers believe these problems are promoted and compounded by poor machining procedures that leave a rough or inaccurate surface. Also, it’s been proved that discs should be as smooth as possible in order to produce maximum stopping power, and sloppy turning will actually make a rotor rougher than it was when it came off the car.
So that leaves replacement, which, besides being fast, amounts to a profitable parts sale for the shop. That doesn’t mean, however, that there are never cases where machining is appropriate, as we’ll explain.
Wobbly
But installing new discs isn’t necessarily a guarantee that you won’t get a repeat pulsation complaint. As Wally Marciniak, Manager of Technical Services for Affinia Under-Vehicle Group (Raybestos brand, www.raybestos.com), puts it, “A lot of people assume that just putting new rotors on will eliminate the problem. But you need to clock them in to get the least possible runout. Check and record runout in all of the possible mounting positions, and use the one with the least. The true runout of any rotor is when it’s tightened down on the hub.” Most authorities say you shouldn’t have over .002 in. of wobble, while others say .001 is the limit.
As we hope you're aware by now, you can keep from causing runout problems by always tightening lugs with a torque wrench instead of your thermonuclear impact gun. Use the proper pattern, please.
A neat way of reducing runout to just about nil is to use tapered shims, such as those made by Brake Align (www.brakealign.com), between the disc and the hub. Of course, you already know that you’ve got to get those hubs as clean as possible so you don’t get a mounting error.
Chain of Events
You may be asking, “Floating and sliding calipers should just ride with runout, so what’s the big deal about some wobble?”
Sure, most calipers slide or float, so you might think they'd just ride with runout. Unfortunately, in the process the discs develop DTV.
Aha, there’s a trick to it, something that many people don’t understand: When it comes right down to basics, the direct cause of pulsation is DTV, which can also be seen as a lack of parallelism between the two sides of a rotor. The wobble we’ve been talking about causes the disc to wear unevenly as it hits those abrasive pads in one spot on each side every revolution. In other words, the contact areas will end up thinner than the rest of the rotor. One on-car lathe manufacturer claims that, typically, .002 in. of runout with zero-clearance bearings will cause about .0004 in. of DTV in 3,000 to 5,000 miles. Some authorities want thickness variation to be held to .0002 in., while others say it will take twice that to generate a complaint. Regardless, you can see that allowing any appreciable wobble out the door can be dangerous to your reputation.
There’s yet another factor that aggravates the development of DTV on late models. To reduce rolling drag, in many vehicles the engineers opted for pre-loaded, zero-clearance front wheel bearings, which require a less scuff-producing toe-in setting. But with no end play to absorb hub and rotor imperfections, any runout at all causes contact between the pads and rotor, increasing the wear that results in thickness variation.
Hand #2
But there’s always the other hand, isn’t there? As you may have noticed, two of the absolutists quoted in the introduction specialize in European cars. At the shop where we were recently working, we’d sometimes pull the wheels off an upscale Euro and know that those discs needed to be replaced by just looking at them. We’re not talking grooves. We mean a visible wide depression made by pad contact.
This is what we call the “Autobahn brake phenomenon.” As Mohammad Vakili, Manager
of Technical Affairs for Continental Teves-ATE (www.conti-online.com), explained to MT, “Vehicle sensitivity in Europe is different … linings are aggressive and tend to produce noise, which is dampened by a soft rotor. In Europe, they design them to wear each other proportionally. They use softer metallurgy than in the U.S. or Japan, where they have milder pads and harder rotors.” So, where we Americans have become accustomed to thinking that rotors should last forever, in European vehicles they’re supposed to wear out along with the pads. That’s the price you pay for being able to “stop on a dime and get nine cents change,” as a brake expert once said to us.
Most of us aren’t Euro specialists, however, so we typically get reline jobs where the rotors are still plenty thick. As we said above, if your test drive reveals no pulsation, swallow your prejudices and hang those pads. In cases where pulsation was the reason the customer appeared at your door, you are probably doing the right thing by machining away the DTV. That is, as long as you take the time to maintain your lathe and use it properly. That’s fodder for another article.
Nobody's going to argue with the stopping power of a BMW brake, but it comes at the cost of faster rotor wear than most of us are used to.
Looks About the Same, But . . .
When replacement is the proper path, how do you choose among the rotors on the market? Do you try to save the customer a few dollars, or would you rather feel confident that the job won’t come back to haunt you?
Vakili tells us that since ATE already makes O.E. rotors, it doesn’t fool around with manufacturing a cheaper version for the aftermarket. If you buy that brand, you simply get original quality. Marciniak of Affinia says, “Whenever a new car comes out, we buy an O.E. rotor and dissect it so we know we’re producing original quality designs and metallurgy.”
The configuration of those fins is an engineered feature. Quality replacements match O.E. no matter how complex, whereas off-brands just do what's easiest (courtesy Raybestos).
This O.E.-quality replacement rotor has a designed-in groove that improves pad wear and performance, and serves as a visual indicator (courtesy Continental Teves-ATE).
Besides metallurgy and internal structure, there’s a factor that might cause serious problems with off-brand rotors that most people aren’t aware of: hub chamfer. If the angle doesn’t match the hub exactly, the disc won’t seat right, leading to big trouble with runout and heat dissipation, yet some cheap items just use, say, 45% as a one-size-fits-all manufacturing convenience. Our advice: Buy brand name only if you want to protect your relationship with your customers and your schedule.
In a Nutshell
An on-car lathe is still an excellent way to assure hat a pulsation problem is well and truly solved (courtesy Hunter Engineering, www.hunter.com)
Here's the on-car lathe Subaru requires its dealers to have. Once you learn the set-up, it produces a beautiful finish (www.procutinternational.com).
In keeping with Master Technician’s mission of offering immediately useful solutions, we’ll boil the above down into a few rules:
* If there’s no pulsation and the rotors are still thick enough (look it up), just hang pads. You may, however, want to service non-unitized wheel bearings, in which case you should mark the rotor and hub so you can assemble them in the same relative positions.
* Whenever you install discs, new or otherwise, get that hub perfectly clean and make sure you mount them in the position that gives the least runout. Also, tapered shims are a great way to eliminate wobble.
* If the grooves are deeper than .060 in., you’re justified in buying new rotors. An easy way to measure the depth of a rotor groove is to use a dime. If the top of F.D.R.’s head is still showing, you’re within the .060 in. limit. If the groove’s too narrow for the coin to be inserted, don’t worry about it.
* If there’s a pulsation complaint, you have a decision to make: machine or replace. If there’s still plenty of thickness left, you can machine off-car and hope for the best (we’re assuming you know how to produce a properly smooth surface — contrary to popular belief, a mirror-like finish would be ideal). Or, you can increase your chances of success by using a good on-car lathe (make index marks for future reference). Finally, there are good reasons to opt for new high-quality discs: They’ll be less apt to warp because they’ll be thicker, you won’t be spending time with the lathe, and you’ll make a nice parts profit. Of course, if the bumpy braking condition is due to a crack, the decision is made for you.
Here’s why...
Early Glimpse
Wobbly
Chain of Events
Hand #2
In a Nutshell
if they're not warped, take some 40grit sandpaper and sand the **** out of them... make sure you get rid of the lip...
often times, i set the rotor up in a brake lathe and spin it up while i sand it...
i DO machine rotors tho... but i measure them after they're cut to see how thick they are...
most performance cars, or trucks with big rotors, i replace rotors on...
Super Moderator
My main "thing" I have against sanding vs. turning is somewhat a personal taste issue. Sanding does not adequately address the issues with the fine radial channels/grooves left behind on the rotors by the previous pads. Do these channels/grooves cause significant harm or a safety concern? no, not really, especially for street cars. Do I sometimes get lazy and just swap the pads and don't bother touching the rotors? on my car, yes. But I'm too tired right now to further discuss the technical aspects of each option, and the channeling/groove concern is my main explanation of my stance.
edit: I forgot to mention, re: the article you pasted. It's funny because our shop bought one of the used brake lathes from the Mercedes repair guys next door. And second, GM's are pretty adamant in not turning their rotors unless needed.
