lexus sc400 help
lexus sc400 help
hey i got two issues with my lexus sc400:
1-the car has stock struts/shocks and i have eibach pro-kit springs
when i go over little bumps or whatever on the road the back shocks and spring combo make this sound like a klunk or something or something sounds like it's not bolted down all the way or maybe shocks are dumping not sure what it is. i lifted the car the shocks don't appear to be leaking or anything and the springs look like they are all put in correct. any ideas on the sound?
2-sometimes either driving or parked i would have my air conditioning on and when i press the off button the a/c turns off and then my car engine turns off immediately after. like the idle goes up then it goes down just shutting the engine. any suggestions to that?
Yes. I drove the LFA.
2. it sounds like you need to clean the throttle body... it probably has a lot of carbon build up on the blade. this can lead to the exact condition you're describing...
