Any opinions or suggestions are welcome. The Chapionbrands seems to be available only in Midwest to West coast. I picked up the Amalie in Connecticuit for $4.71/ quart.
Usually you will only have problems (after changing your fluid) if you havent changed the fluid in a long long time... Ive heard that the Amsoil stuff is great. I used their engine oil in my camaro a few years ago and i had no complaints.
I don't think the drain and fill will damage your transmission, it's the full transmission flush on a machine that hurts. Correct me if I'm wrong.
Is it bad to mix two different brands? Can I switch to a different brand next time I do a drain and refill or do I need to do a complete flush before I switch brands?
I have amsoil and toyota fluid mixed in my tranny. I have no problems at all.
same here... however, I did read once that you are not supposed to mix Type T-IV and Type T-II... there was a Toyota TSB about it... not sure how crucial it is though...
Yea I don't know how crucial it is either but I wouldn't mix two different types of ATF. As long as it is ok for two different brands but both same type, I'm good . Thanks guys.
I forgot to mention, is the stuff at Autozone compatible? I think I remember hearing some bad stuff about that but can't remember. Would mixing that with the toyota fluid bad?
