Is Royal Purple 5w30 any good?
Old 07-09-07, 03:44 PM
  #31
TunedRX300
TunedRX300's Avatar
Originally Posted by Max707
It's your ride and you pay the bills do what you want. I have no problem with well thought out mod's. 5w30 might be a good thing for someones driving needs. I would first check out bob is the oil guy sight and see what some of the more well informed oil experts thought and also look at some UOA's using 5w20 in vehicles that the manufacture indicated 5w30. Racing a RX???
Toyota has released an official TSIB to recommend 5w-20 and 0w-20 last year. Exact quote from Toyota
This oil is superior in terms of fuel economy, engine protection, and cold starting performance.
Most 5w-20 UOAs posted BITOG show better wear number than 5w-30, which verify claims made by Toyota.
Old 07-09-07, 04:29 PM
  #32
Max707
Max707's Avatar
Reread your post where it says *Note* use the grade oil that is indicated on your oil cap. Mine says 5w30.
Old 07-09-07, 04:52 PM
  #33
TunedRX300
TunedRX300's Avatar
5w-20 and 0w-20 are factory filled in these engines at Toyota's plants starting at March 2006. If you search, you will find owners are confused that their oil caps say 5w-30 and owner's manuals say 5w-20. Most owners should be smart enough to look into reasons behind oil recommendation instead of blindly following an outdated mark. Especially when Toyota simply do not want to scrap an huge inventory of outdated cap.
I realize there are folks that must use XXX despite indepent scientific data and what OEM uses here. That is fine but let's not question other's experience w/o some facts.
Old 07-09-07, 04:53 PM
  #34
geko29
Super Moderator
geko29's Avatar
Originally Posted by tmf2004
Has something happened to Mobil 1 synthetic? Its a pure synthetic right? I used to use RP in my mustang when i had it.. I remember getting the headgaskets replaced and the block was as clean as a whistle inside.. I guess switching to RP won't hurt anything right? BTW isn't the GS rated for 5w 30 anyway?
I know this has already been answered, but I wanted to go into a bit more detail for you. Most grades of Mobil 1 are made almost entirely of Group III base oil. That is, dino (conventional, or Group II) oil that has been chemically modified for better lubricity and other characteristics. True synthetics are Group IV (PAO) and Group V (Ester) bases. Mobil 1 does include a SMALL amount of PAO in all their oils. They call it "SuperSyn". They toss a bit of REAL synthetic oil in there as an additive and pretend that it's a full synthetic oil, because US law allows them to. If you want a REAL synthetic oil, you need one of the following:
Amsoil
Royal Purple
Redline
Motul
German Castrol
There are a few others, but those are the biggies. Nearly every multiweight oil (those with a w in the designation, like 5w30) you can buy at your local store is a fake Group III "synthetic" just like Mobil 1.
Old 07-09-07, 05:20 PM
  #35
Max707
Max707's Avatar
What are you talking about. My 2004 recommends 5w30 not 5w20. Based on research I would rather use a 5w30 then a 5w20. One of the big reasons that all of the auto manufactures are going to 5w20 oil is it increases gas mileage, do your research it is better for the manufacture not better for the long term dependablity of your engine.
Old 07-09-07, 05:39 PM
  #36
GSteg
GSteg's Avatar
TunedRX300 is saying those with newer lexus (2006+ models) will find that their oil cap says 5w-30, but the manual will state 5w-20.
The newer 06+ GS430 uses the 3UZ-FE engine that is carried over from the 01-05 GS430. The engines are exactly the same in both cases, yet one says 5w-20 and the older one says 5w-20. If Lexus is able to switch over to 5w-20 on factory fills, then there is no reason why the guys with the 01-05 GS430 can't do the same.
Old 07-09-07, 05:45 PM
  #37
Max707
Max707's Avatar
Why would they want to do that? Less protection for their engine. Same 5 weight for both oils when cold and when hot the 30 weight gives better protection over the 20 weight.
Old 07-09-07, 05:57 PM
  #38
GSteg
GSteg's Avatar
If toyota was aware that 5w-20 would give their engines some sort of failure, I would think they know about it by now. Fact is, not only Toyota is switching to 5w-20.
I use 5w-20 in my engine because my engine doesn't even get up to temperature, so 5w-20 works better. And plus like TunedRX300 said, UOA have shown 5w-20 to wear better than 5w-30. Personally I dont have any trouble with both viscosities.
Old 07-09-07, 06:18 PM
  #39
TunedRX300
TunedRX300's Avatar
GSteg,
Thanks for clarifying what I meant.
To give another example, Acura/Honda made the switch in 2002, the TL did not make a single change in the J32 engine. Junk yard are not filled up with post 2001 TLs with dead engines either.
What is the point to show further data? Logic, Toyota official statement of 20 weight protecting engine better, and BITOG UOA data won't make a single difference if one choose not to believe them in the first place. Just not worth it.
Old 07-09-07, 06:57 PM
  #40
firewire
firewire's Avatar
Just used Royal Purple for the first time ever and noticed that it's transparent in color! I have never seen oil this transparent. Is this normal?
Old 07-09-07, 08:17 PM
  #41
Max707
Max707's Avatar
Why doesn't my local Lexus dealer use 5w20 in my 2004 LX470 if it is a better oil then the 5w30?
Old 07-09-07, 09:30 PM
  #42
GSteg
GSteg's Avatar
because the TSIB is for 06+ and they'll service cars accordingly to what they're told to do. For the home mechanics out there, they'll change it to 5w-20 if they know it's better.
Old 07-10-07, 06:21 AM
  #43
Max707
Max707's Avatar
OK, can you point me to some expert analysis that shows it is better for my engine, other then MPG? Will it make my engine last longer? Will it give me better MPG with no adverse effect? Just want to see some study info versus assumptions that since the manufactures are changing to 5w20 it must be better. Thanks
Old 07-10-07, 08:44 AM
  #44
2007es350
2007es350's Avatar
The LS460 calls for either 5w20 or 0w20. It is far less convenient to hunt down this weight....but I'm definitely going to follow the factory recommendations.
Old 07-10-07, 10:57 AM
  #45
UberNoob
UberNoob's Avatar
so my local autoparts store sells 5w20 for $5.52 CAD per liter
plus some environmental fee that government charges for all engine oil and stuff...
so thats like approx. $5 USD per quart
is that a good price?
can i mix it with the mobil 1 5w30 that i still have?
or castrol GTX 5w30?
or should i just give the GTX to my friend?
Quick Reply: Is Royal Purple 5w30 any good?
