Car won't stay on after it starts, HELP!
Old 07-12-07, 06:29 PM
toy4two
toy4two's Avatar
those bolt are soft metal and phillips, even with the correct #3 phillips I stripped one out, wish Lexus used hex heads or a nice bolt you could take off with a socket would have been nice.
I gave up trying to get it off, just put everything back on, sprayed the port with carb cleaner, followed it up with a can of compressed air and called it a day.
Old 07-12-07, 09:41 PM
RTIS250
Yes. I drove the LFA.
Senior Moderator
RTIS250's Avatar
The screws are known to strip out, they are pretty tight.. i usually tap them with a small hammer so break the grip a little. And if they do strip, i just drill them out. There are two screws that hold the plastic part to the base, you can take those off the hold IAC, and use one in place of the stripped one.
Old 07-14-07, 03:24 PM
Meetya
Meetya's Avatar
Guys, if you remove IACV, you will have to replace the rubber gasket. It looks similar to this:
It will buff once exposed to air and won't fit back. It's only $2 and available at any dealer. Part #22215-20010.
Here is more info:
https://www.clublexus.com/forums/sho...d.php?t=285766
Old 07-14-07, 03:29 PM
Meetya
Meetya's Avatar
Yeah, I remember I had to use Dremel to make a slot in one of them and unscrewed it using a flat head screwdriver.
Old 07-14-07, 03:50 PM
Meetya
Meetya's Avatar
Originally Posted by OceanView
OK, I am trying to determine exactly where I am suppose to spray the carb cleaner.
Please look at the photo.
Do I spray in part A or is there something behind part B that I spray into?
Thanks for your help.
I also used another method of cleaning. Expose throttle body intake (as you have on your last picture). Disconnect the air line from IACV. Make sure you have disconnected the air line, not the coolant line. Get a kitchen sink hose from Home Depot. Connect it to the bottom of IACV and spray carb cleaner or alkali (purple degreaser from Walmart) into the hose and then blow it thru with compressed air. Repeat, until you see no more crap coming out from the top. Make sure not too much of the stuff gets into your intake; just put some paper towels in there to absorb liquids. I would not recommend cleaning thru rubber hose you already have on your engine -- cleaners can ruin rubber. Use silicone kitchen hose instead.
Old 07-14-07, 06:54 PM
toy4two
toy4two's Avatar
any tips on drilling it out? I tried and went through 2 drill bits, no luck.
Old 07-14-07, 08:14 PM
Meetya
Meetya's Avatar
I would recommend to completely cut off the head of the screw [with a short file or Drimell], pull out IACV and then apply WD40 and to what is left, loosen the thread part of the bolt with pliers and remove the sucker by hand. Then go to Home Depot and buy 4 new metric screws with hex heads.
Old 07-30-07, 10:29 AM
OceanView
OceanView's Avatar
UPDATE:
I sprayed 3 seperate times into the hole as recommened by many on this thread but the car still has the same starting problem.
I also noticed that once I get the car started and it stays on, the idle speed seems to be lower than normal. It is idling around 500 RPM (700-800 RPM was normal before). Not sure what to do next as I have no clue about this issue.
EDIT: IACV seems to be the problem.
Old 08-12-07, 10:25 PM
SilverSprt
SilverSprt's Avatar
Oceanview, I wrote up a step by step DIY on how to clean the IACV. The post is for an RX300 (3.0L). Should be similar for the ES300 models. The following post addresses the very same issues you are talking about regarding the stripping of the bolts. Hope this helps.
http://us.lexusownersclub.com/forums...howtopic=30723
Old 08-13-07, 12:31 PM
OceanView
OceanView's Avatar
I saw that yesturday and did the cleaning myself.
Very helpful for me.
Thanks
danfall4
02-24-16 07:37 AM
asam123
03-08-13 09:56 PM
spitvenom
05-27-12 08:53 PM
oystrpearl
12-29-08 12:53 AM
myztikal47
09-08-06 12:32 AM
Quick Reply: Car won't stay on after it starts, HELP!
