Changing Brake Pads
I will post a pdf of the Highlander Brake Pad replacement, should be the same or close to it.
Thanks, I'll be looking for your pdf.
And I know it won't cost much but sometimes it is nice to just do the work yourself.Kind of getting your hands dirty makes one feel good.
Brake Pad Replacement
I actually have the Rx330 pdf, I will post in the morning.
Front Brake Overhaul
Here you go chief!
Brakes
Components for the front.
Good luck! I normally take pictures before I tear them apart, helps me keep up with it when it is time to put them back. DIY pictures would be good, if you are up to it!
Maintenance Moderator
a couple quick notes - there is no reason to rebuild the calipers if you are just doing a brake job... also, no need to disconnect the brake lines from the calipers - just use a coat hanger and hang them up and out of the way while you do the rest of the work....
danny10989
Suspension and Brakes
09-05-09 11:43 PM
