2001 LS430, 53k service...am I leaving anything out?
I know some of this doesnt have to be done right now, but I want to get everything done I possibly can to make this a "might as well be new car".
I'll start with all new hoses and belts (incl. timing belt), water pump, tranny fluid flush/fill, rear diff flush/fill, brake pads, spark plugs
Am I missing anything to make this "new" again?
This is what Edmunds says:
Inspect Ball joints $ 4.28
Inspect Brake system $ 12.82
Inspect Cabin air filter $ 12.82
Inspect Chassis & body $ 2.14
Retorque bolts Drive shaft $ 4.28
Change Engine oil $ 8.55
Replace Oil filter $ 4.28
Perform Road test $ 4.28
Inspect Steering linkage $ 4.28
Rotate Wheels & tires $ 12.82
Im not sure why you would want to do the timing belt at 53k miles.. its not even due until 90k. Its completely unnecessary. Same goes for the Iridium spark plugs you have in your car. Otherwise, you pretty much named everything. You can also flush out your brake fluid.
i know is doesnt NEED to be done right now, but basically I'm in a situation where I was told "do whatever you need to, to make it 'new' again"...as in i'm not paying for it
so I'm just trying to cover everything I can...
Well if their really going to go the extra mile & pay for all this I would get a new maf sensor (yes I know it is really a Karman Vortex unit) thrown in for good measure. Yours still works fine but it isn't new. Had to pick up at least some dirt & residue somewhere.
Flush/replace the power steering, tranny & brake fluids
