Alternator longevity
Honestly, i havent seen a set range on when they usually go out... ive seen them crap out at 50k miles, and ive seen them go as long as 200k miles. The usual issue on the LS/GS is that the power steering pump leaks onto the alternator shorting it out. But have an alternator go out on its own, its not exactly common, but not hard to beleive either.
frankly speaking... i have expereinced alternator failures but not with a toyota\lexus...i dont want to mention the brand.. but it was a 850rwhp.. and alternator failure was due to its bad ECU programming which then had to change the alternator.. !
My Aristo (2JZGTE VVTi).. running 150k and thank God no alternator probelms what soo ever !
from my expereince...when a car is parked for a long time.. usually the alternator starts screwing up.. ( function of time ) !
my apologies got nothing more to add !
I usually get around 90K on my Toyota alternators. My wife's Dodge van, OTOH, got over 160K on hers.
If you have an electrical repair shop that will work on alternators you can save a bundle. The last alternator I worked with could have been replaced by Toyota for around $300 or traded in for a rebuilt at Pep Boys for $80. Instead I took it to this little repair shop downtown where they replaced the diodes for $6 plus $20 labor. I had it back the same day.
