Two hoses #6 near T/B
Hey guys,
Tried searching for this, but all out of luck.
I have a problem. The other day I was trying to clean my EGR and I noticed 2 loose "hoses". I tugged a little and sha-bam, the 2 came off. Now every time I start my car, the TRAC light between my RPM gauge is on.
I really have no idea where does these 2 hoses go to. Anyone can put me into the best way to put this back? Below are some pictures I just took today. The hoses are labeled #6 if anything helps. Thanks in advance.
The car is a 1992 SC400
_____________________
[IMG][/IMG]
[IMG][/IMG]
Yes. I drove the LFA.
Ok, so i dont have a picture, but i checked out an SC400 we had on the lot here. Right below the passenger side valve cover, below the intake tube, there is a VSV (vacuum switching valve), and it accepts the two vacuum lines you are holding. So take off your intake boot/tube, and it should be right under there. I will try to snap a picture.. cause i cant find it in the repair manual at the moment.. but i will keep looking.
xspsi6
SC400 / 300 Classifieds
05-08-12 02:17 PM
