Opinion wanted about control arm replacement
My local repair shop says I need a lower control arm on my 95 LS for state inspection. They quoted me 500 bucks to repair including an alignment. It's just the bushing that's bad, but they claim they cannot buy anything but a replacement arm. Don't think they really want to be bothered with locating and then pressing out/in the bushing. Does this price seem reasonable ? Also, they didn't suggest it, but shouldn't I replace the lower ball joint at the same time ?
Thx
Thx
That's way too much , Toyolex has the bush for about $50.00 .
Also you should do both sides and the ball joints while you are at it .
If it was me I would be doing rack rubbers and sway bar rubbers also and while it was apart get them to check out the upper control arms , they are availiable from Arnotts now for $200.00 the pair .
On your 1995 LS, it's the caster arms that goes bad. It's mount on the lower control arms on one end and the other end mounted on the sub frame that hold the engine. When this bushing goes bad you can hear it pretty well went you step on brake at low speed(clunking noise).
You can't buy just the bushing.For $500.00 with parts and labor and alignment sound about right.
Well there are control arms in the front and rear... so i didnt know which. After re-reading your post, you talk about ball joints, so now i can see you're talking about the fronts. The part you're talking about, is usually refered to as a "strut rod" at my shop. it goes from the spindle to the front end of the frame and has a rubber bushing on the front. Or are you talking about the lower control arm itself.. either way, i think 500 is a decent price for that work, and yes, i would probably do ball joints at the same time, it shouldnt be any additional labor.
not sure but when you guys mention the "Caster Arm" what exactly are you talking about. I know that both VVT-i and RTGS400 are lexus techs and all but iirc the front lower suspension on the 2nd gen LS400 had basically:
-Lower Control Arm
-Lower Ball Joint
-Strut Bar
-Hub/Knuckle assy.
-tie rod end
and of course shock mount and a couple braces.
normally on the 95-97LS what goes bad first are the Strut Rod bushings, which are available from sponsor L-Tunedparts for about $100ish/side (whole bar w/bushing) or about 45-50/side for just the bushing.
if the Control arm bushings are bad you are looking at around $250-300/side for OEM control arms (good idea to do both sides together). not sure about control arm bushings, i know Lexus doesnt offer them but aftermarket may or may not be available. No, 89-94 aftermarket bushings will NOT fit.
if they Lower Ball Joint is bad, just replace it
relatively cheap and low labor. if the shop states that the lower control arm is bad, ask them if it is the lower ball joint or the bushings in the arm themselves, as a lot of shops will order the parts for and therefore get the labor money for doing a full LCA swap where a mere LBJ swap is needed.
oh yea, how the hell would bad LCA bushings fail u during a state inspection????? ball joint i could understand but BUSHINGS?!?!!
-Lower Control Arm
-Lower Ball Joint
-Strut Bar
-Hub/Knuckle assy.
-tie rod end
Yessir, I guess it is. Just wondering whether their estimate includes the ball joint ? Kinda doubt it , since no mention was made of the ball joint. But, it would seem rather silly to replace the arm and not the ball joint, wouldn't it ?
I think that part (lower control arm only) lists for @ 120 bucks ? If that's the case, the 500 does seem a bit steep.
"On your 1995 LS, it's the caster arms that goes bad. It's mount on the lower control arms on one end and the other end mounted on the sub frame that hold the engine. When this bushing goes bad you can hear it pretty well went you step on brake at low speed(clunking noise)."
I've had this "clunking noise" for about a year now. I haven't felt any problem with steering, braking, etc.. I thought it might just be the backing plate for the front brake. My tires seem to be wearing evenly (no pull to either side). So, if it's the caster arm, what should I be concerned about? Could my lower ball joints break? Something real bad happen? Any way for me to check it out? Thanks for any feedback.
Thanks. Well according to the shop, it was just the bushing that was bad, but they had no access to the bushing alone, hence the need for the entire arm. To answer one of your earlier posts Drifter; I think they are saying that it requires replacement to pass our state inspection requirements. They said nothing bout the ball joint. Mebbe a communication prob ?
Suppose I'll ask how much add'l a new ball joint will cost and do the job right.
