Mistsuguy!! Power Steering Pump Replacement
Maintenance Moderator
heh, not much in the way of help as far as instructions...
it's very straightforward though...
Rotate drive belt tensioner clockwise to release belt tension,
disengage belt from p/s pump pulley
disconnect pressure and return hoses
remove mounting bolts and pump
reverse...
then bleed by having car running and moving steering wheel back and forth - stay at each lock for 2-3 seconds, then turn back...
reverse...
reverse...
reverse...
Mitsuguy to the rescue again Thank you man,
Jonny
2jznosht
Performance & Maintenance
06-20-23 10:35 AM
BrittonJ85
04-28-10 10:39 AM
