Maintenance for 100k
My 02 ES300 is approaching 100k pretty soon... what needs to get done?
Timingbelt
water pump
acc. belts
coolant
tranny drain/refill
oil change
spark plugs
plug wires(neccessary??)
pcv valve
fuel filter
is there anything im missing??
Timingbelt
water pump
acc. belts
coolant
tranny drain/refill
oil change
spark plugs
pcv valve
fuel filter
The differential is integral of the transmission and takes the same T4 fluid. Definately do your cam and crank seals if you're going to have the t-belt apart. Might as well do the idlers for the timing belt as well. You dont have spark plug wires, so nothing to replace there. Might want to consider flushing the brake fluid though. Otherwise, it sounds like you got everything.
montymaple
06-11-12 04:14 PM
