peg clips for engine shroud cover
does anyone know if the plastic peg clips used to fasten the plastic engine shroud covers can be reused ,or if new clips are needed. If so, where can I get new ones, as the one I removed is loose. Thanks
The peg clips I use are 'resetable' .. There is an inner peg inside the outer ring. I use a small flat head and pull up on the inner portion and then it is 'ready' to go in. I pop it in, and push down and it is solid. Removing it I do the same process. Though I could pry it completely from the edge.. I think prying the center portion is proper if you can't access beneath it.
