VSC, Brake Light, abs lights - all on
my RX300 has all 3 lights showing on the dash. lexus dealer said the whole loom needed replacing as probably corroded. Had loom checked by independent Auto Electrician no sign of corrosion. codes are co274, c1223
Electrician thinks he has traced it to problem with the brake Pump -does anybody know the resistance in Ohms associated with this component
anybody got any ideas? or had similar problem. any help appreciated
Welcome to Club Lexus.
The 3 warning lights always come on as a check-engine indication. I guess Lexus figures that 3 lights will be easier to notice.
I'll leave it for others to interpret the 2nd Generation On-Board Diagnostic (OBD-2) codes. I would think a bad cable harness would be fairly unlikely, but possible I guess.
Redeemed07
08-15-18 11:26 AM
