Forgot to put the oil plug gasket back on
First oil change, i did everything well except that i forgot to put the oil plug gasket back on. The last person to do oil change was a mechanic so i thought it didnt have it but it turns out it fell into the oil pan. Is it ok to drive without the oil plug gasket if the oil doesnt leak? I'm either going to to put it back on or at next oil change.
i did the same thing and i didnt leak for a really long time , and then i noticed that it was leaking very very little bit . .. . . ..
jus do another change . ... .. but dont forget the washer =)
Put a piece of cardboard under the pan when you park it for the night. In the morning, check to see if there is any oil leaking. If not, your fine. I would probably do this once every month until next change and you can get the gasket on there
pauloil
06-21-13 08:09 PM
